I try msys.bat and work it but follow error
http://i.hizliresim.com/L1mLAa.png
Results 1,921 to 1,950 of 2222
It seems that compiling failed, therefore no exe and no dll exists.
Running ./remake_x265.sh should take a while if it is successful, and produce a lot of console output. Are there any error messages? Maybe I forgot to mention that you have to install CMake as well... -
You should have executed hg clone https://bitbucket.org/multicoreware/x265 and then ./uptodate_x265.sh once to prepare your local source copy and the building subdirectories. Then...
To build the revision with the tag "1.7":- hg update --cwd x265 -r 1.7
- ./remake_x265.sh
- ./makemulti.sh
- ./release_x265.sh
- Archive the content of C:\MSYS\home\2016\release after testing if x265_ml -V in C:\MSYS\home\2016\release\Win32 reports the version correctly.
To build the revision with the tag "1.8":- hg update --cwd x265 -r 1.8
- ./remake_x265.sh
- ./makemulti.sh
- ./release_x265.sh
Please note: Trying to build versions before 12 bit code has been developed will probably fail without editing the shell scripts. -
Hi @LigH.de, me again. What code 8+10 bit for multilib.sh ? not 8+10+12. only 8+10
you would need to modify multilib.sh to only build 8+10 -> Have you ever read it and understood how it works?
users currently on my ignore list: deadrats, Stears555, marcorocchini -
If you are using Visual Studio, editing and/or using multilib.sh which is a shell script meant for linux enviroments, doesn't make any sense at all!
What you need to edit and use is the multilib.bat which resides in the corresponding build/vc... folder which matches your Visual Studio version.
Looking at for example at: https://bitbucket.org/multicoreware/x265/src/425b583f25dbb57af86fc5c128548038954baf31/...e-view-default
you would need to delete:
Code:@mkdir 12bit
Code:@cd 12bit cmake -G "Visual Studio 12 Win64" ../../../source -DHIGH_BIT_DEPTH=ON -DEXPORT_C_API=OFF -DENABLE_SHARED=OFF -DENABLE_CLI=OFF -DMAIN12=ON if exist x265.sln ( MSBuild /property:Configuration="Release" x265.sln copy/y Release\x265-static.lib ..\8bit\x265-static-main12.lib )
and exchange:Code:if not exist x265-static-main12.lib ( msg "%username%" "12bit build failed" exit 1 )
with:Code:cmake -G "Visual Studio 12 Win64" ../../../source -DEXTRA_LIB="x265-static-main10.lib;x265-static-main12.lib" -DLINKED_10BIT=ON -DLINKED_12BIT=ON if exist x265.sln ( MSBuild /property:Configuration="Release" x265.sln :: combine static libraries (ignore warnings caused by winxp.cpp hacks) move Release\x265-static.lib x265-static-main.lib LIB.EXE /ignore:4006 /ignore:4221 /OUT:Release\x265-static.lib x265-static-main.lib x265-static-main10.lib x265-static-main12.lib )
Code:cmake -G "Visual Studio 12 Win64" ../../../source -DEXTRA_LIB="x265-static-main10.lib" -DLINKED_10BIT=ON if exist x265.sln ( MSBuild /property:Configuration="Release" x265.sln :: combine static libraries (ignore warnings caused by winxp.cpp hacks) move Release\x265-static.lib x265-static-main.lib LIB.EXE /ignore:4006 /ignore:4221 /OUT:Release\x265-static.lib x265-static-main.lib x265-static-main10.lib )
If you use GCC, you should edit the multilib.sh and remove everything related to the 12bit library.
Can't follow you, .... your are not usign the multilib.sh, but the makemulti.sh and that still contains lots of call related to 12bit,....
New build with changed 2-pass VBV-CRF conditions (AFAIK, you have to add --vbv-maxrate {kbps} in 1st pass to enable the use of a CRF value for VBV-constrained CRF mode instead of a target bitrate for VBR mode in 2nd pass):
x265 1.9+15-425b583f25db (GCC 5.3.0)Last edited by LigH.de; 15th Feb 2016 at 04:17.
Some more bitrate control enhancements in x265 1.9+88-b6d8e66e7f71
x265 1.9+96-b09998b1256e should have fixed the bitrate control for zones.
Experimental UHD Bluray support (--uhd-bd) in x265 1.9+106-c8ec86965e54; is there anyone who can test and confirm?
Is there some sort of overview what this should do?
http://x265.readthedocs.org/en/latest/cli.html?highlight=--uhd#cmdoption--uhd-bd isn't really informative and so a x265/H.265 specific overview would be helpful.users currently on my ignore list: deadrats, Stears555, marcorocchini -
I don't know any other detailed documentation yet. For now you may have to inspect the patch source. Sneaker already found a few flaws, reported in the doom9 forum.
Several fixes regarding UHD-BD, dithering of different color depths, and documentation clarifications:
x265 1.9+125-40afead3177d -
I don't have any player or authoring tool, so I am not sure; if I followed the doom9 forum discussion involving a spec verifier well, I believe it is not yet done, there is an issue left regarding the structure of open GOPs (the number of contained frames may get counted beyond the maximum of allowed frames per GOP). And there may be still undetected issues... who knows. The number of available devices and authoring software is small. But if you set x265 up to comply with specified ranges and use only closed GOPs, the result should already be very compatible.
x265 1.9+140-34a3d35c5f97: UHD-BD compatibility forces closed GOPs; --limit-refs clarified to be on/off; and a bunch of fixes and speed-ups (ARM implementations don't matter for x86 platform)
x265 1.9+150-00ea3784bd36: Unicode filenames support for output and stats; and some rate control improvements
x265 1.9+167-bebae72f9db7 provides a few changes regarding the grain handling, and a new tweak:
Code:--[no-]recursion-skip Enable early exit from recursion. Default enabled
x265 1.9+183-4723933fdec9: --slow-firstpass is now enabled as default; quantization is clipped in 2-pass with grain tuning; --qpfile and --csv support Unicode too.
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 01:33 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 07:14 -
ffdcaenc (an upgrade to dcaenc)
By El Heggunte in forum AudioReplies: 22Last Post: 9th Dec 2014, 07:09 -
MulticoreWare Annouces x265/HEVC Mission Statement
By enim in forum Latest Video NewsReplies: 4Last Post: 9th Aug 2013, 23:09 -
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 17:57
okay i did
